KeavDog
Charger Build Under Way
159 posts in this topic
Sure hope that one works - since it says 2010 5.7 Challenger and I have a 2009 5.7 Charger lol
Definitely a different animal compared to the other bracket!
it does work...... lol
The air conditioning hose didn't like it much though....
This is a nice kit BTW
More stuff on order - to get the power to the track!
Afco Mopar Dragpak shocks/springs
TCE wilwood 15" rear brake conversion
Spohn rear suspension kit
HHP Solid diff pinion bushing
Whiteline rear subframe front/rear bushings
A few more tune tweaks from Josh and this car should be at Spring Festival. Drive it around a bit change the oil then install the fuel system then off to the Dyno...
That was a tough 6hrs, well worth it though.
Not quite 14 lbs of boost
No KR at that afr with C16
Never saw over 120 IATs with the complete Pro Charger kit
Inertia VVT SB, heads and cam, One of the best I know of......
Modern Muscle ported 6.1 manifold, A thing of Beauty......
BB/Paramount trans, Head jerking shifts......
Justin at Fore is great to deal with, available anytime.
Parts bought from: HHP Thanks Josh, Bruce, Don
Pro Charger kit
ATI over drive
Fore fuel Hat, fuel rails, injectors and return system
AFCO shocks
Cradle bushing kit
Diff mount kit
15" rear brake kit
Kooks 1 7/8 headers, cat less mids
HHP tuned, Josh you are a patient man, Thanks a bunch!!!
I hope there was nothing or no one left out........ :)
Now lets go hit the track John.
