Scamp
300c
I bought a 2005 300C for a winter car. It is nice but not perfect. I m pretty sure  it needs a clock spring (air bag light ) but what im wondering is the cruise doenst work. It will turn on and but wont set. Could it also be caused due to the defective clock spring
I cleared all the codes with a scan tool, did have a pending code before (p1417 . Cylinder 7 Reactivation Control Performance)I know that code was pending but it was -25 celus and so far the code hasnt returned or pending.
k, if the cruise turns on it's not the clock spring. I would look at the ABS with the scan tool and see if there is a questionable wheel speed sensor.
If a wheel speed sensor is bad wont it not let you arm the cruise control? That's what mine does anyways.
