JDW RT 09
U-joints? 2003 Ram
Metal grinding sounds inside the vehicle consistent with vehicle speed and occasional clunk after putting into gear. Haynes manual says U-Joints if there is any play or movement if trying to move them by hand. I have a little movement in the front u-joint and the book says any movement means considerable wear.
Anyone agree this is a u joint problem?
So is this a DIY job or I got a quote for $200 from a local shop?
$200 seems reasonable.
Sounds like a definite possibility. They can cause a vibration even before they get play in them if they dry out. The front joint on the front driveshaft isn't hard to replace if you have a good vise or a press. The rear joints on the front shaft are coupled together and are a pain in the ass. Also check the joints on the front axle they go bad pretty easily as well.
So I did this on my own. Never again.
Front and rear u-joints, extension housing oil seal, rear pinion seal. Man did it suck. If this is ever a problem again, its going to the shop. I'm out.
Getting the old seals out, removing and installing the ujoints. Was just a pain in the ass. Went by the Haynes manual but doing it for the first time was still difficult. Even though I now know how, it's not worth the effort.
