Rat Patrol
Correct Plug Gap?
I am running  LZTR5AIX13 - NGK 2314 plugs which have a heat range of 5.
Motor is basically stock - with a mild cam.
What would be an appropriate plug gap , factory spoec or do the iridium plugs require a different setting?
just me but that seams to be a pretty cold plug for a basically stock motor.. i would step up to a 2315 which is 1 heat range colder than stock
hope that helps
5.7 HEMI Applications:
�NGK 2313 Iridium Spark Plug (Stock Heat Range for HEMI Rams and Most 5.7L LX cars) �NGK 5306 Traditional Spark Plug (Stock Heat Range for HEMI Rams and Most 5.7L LX cars)
�NGK 2314 Iridium Spark Plug (One Step colder heat range plug than stock) �NGK 4306 Traditional Spark Plug (One Step colder heat range plug than stock)
�NGK 2315 Iridium Spark Plug (Two steps colder heat range plug than stock)
6.1 HEMI Applications:
�NGK 2314 Iridium Spark Plug (Stock heat range plug for 6.1 HEMI) �NGK 4306 Traditional Spark Plug (Stock heat range plug for 6.1 HEMI)
�NGK 2315 Iridium Spark Plug (One step colder heat range than stock)
