RT6SPD
1972 F100 Stepside Project. Polishing The Mag Wheels.
polished out my mags on the truck the last couple of days.
Method:
remove mag from vehicle
spray wheel with WD40
polish wheel with mild abrasive scotch brite pad or steel wool
wipe mag
polish with aluminum mag polish using wax application pad
wipe mag. power buff with drill and buffing pad if desired.
Front Mag done, Rear mag not done yet.
Mag before polishing
Mag after WD40 and scotchbrite polishing
After mag polishing with Mothers aluminum mag polish not wiped yet
mag polished out with microfibre cloth
Mag after power polishing with drill and buffing ball
Finished Product
man it takes a long time to post pictures properly.
Hope this post is both enjoyable and informative.
might need to sand with 320 grit & WD40. but try the above first
You should be able to tell after the first step.
Um... not a shitty camera.... a shitty old Iphone4
camera lens is scratched up but it plays tunes great. And phone and internet work well.
