Renfrick1
Data Logging
I'm having trouble DL. I had a wb installed and I followed speedys video on how to wire it up useing the digikey end. I uploaded the pid af on the trinity and set the measuring limits min - max. changed it to percent. My values change back to 7.00 and 22.00 once I start DL. when I send the file off the mike he says he can't see my af. Anyone have any idea on what ive done wrong?
Something about it changing to 7.00 and 22.00 (instead of 7.39 I believe) is off -- like you chose volts as a unit or something.   I say go edit the gauge in Trinity to make sure you set the max/min values (and units) correctly.
When you monitor (not record), do you see the AFR change?
