RonP
?'s About Afr In Different Gears & Changing 5.7 Calid To A 6.1 Calid
So I have always noticed on my logs that as I get into the upper gears my car gets richer at WOT.
At VMP in Sept it was fairly warm and my AFR in 1st was 11.5-11.7. It gets progressively lower (richer) as I go down track and  by the time I was in 3rd and even into 4th right before hitting the stripe I was 10.9-11.2.
So now its cooling down a lot and I am running tomorrow. yesterday I saw the 1st gear AFR climb into the low 12's and I have a feeling it would be closer to mid 12's at the track. So I am going to add fuel, but I will still have the same issue I believe. Richer as I get down track.
Is this common? Not questioning my tune...simply trying to learn this shit and see what others see.
Also, as I prepare for the new engine and higher boost and such...Should I have my 5.7 CALID flashed to a 6.1?
Does that provide the tuner more ability? is it worth it? and can a dodge dealer do it? I have a good friend at the local one but not sure if he is up on all this.
Thanks
Aside from cat protect causing rich IATs the load changes in the higher gears which cause a change as well.
Thanks Erik,
I know the CAT is turned off and I figured it was due tot he load changing, so is it just the way it is? or is there more tuning ability with a 6.1 CALID? Since it looks like all I can do is add or take away fuel in RPM ranges..
Its just the way it is unfortunately. I will go a hair leaner in first and second on Wendy's car and keep the higher load closer to where I want it in 3rd and 4th.
