tomoro
Thanks Dss !!
Good communication !!
I'm really happy!
I bought 1 piece aluminum for my 300c because I twisted my stocker
come with spacer to drop diff and cross member
I have 2 question...
-it's normal this place between exhaust and Driveshaft ? it'S very tight ...
-I need change bolt for cross member ?  because with spacers I don't have a lot of threads (3/16)
can't go wrong with DSS. Frank and the crew are top notch for sure!
and yes, depending on the exhaust system, the fit is tight.  i had extensions welded into the hangers by the diff to allow the exhaust/mufflers to hang a bit lower and give more clearance.
perfect I will change bolt for longer  and I will check my DS if my exhaust hit it
someone have dimension and thread of these bolt for cross member ?
thx
