BADPLM
Finished Na Build - Chime In
32 posts in this topic
2010 SRT8 Challenger / 6 speed / 18k miles
6.1 stock bottom end.
GTP Stage 2 heads.
Mackbuilt ported intake
FRI Little Boy Cam on a 112 LSA / 214/218 duration
Stainless works long tubes & catless mids / Corsa extreme
Mopar CAI
New plugs
EFI Specialities base tune.
Dyno tune on a Mustang dyno scheduled for Friday.
1. Can anyone think of anything I have overlooked in my NA build?  (besides SC or Turbos  :P )
2. Anyone willing to toss out some numbers on what it might make?
On a mustang? 395-410 rwhp. With all the work why did you choose a littleboy cam?[/quote
Went with it based on recommendation from my builder. He's had good results with it. Just cam / manifold made 412/412 on a dynojet. Adding tubes and heads should net me another 30-40 hp I hope. I don't have access to the dynojet that we made our last pulls on. Not sure how to interpret gains on the Mustang dyno
I would be shocked to see 30-40 from tubes and heads, especially without a substantial cam. the stock heads and shorties are pretty damn good. and I would think are adequate until you get into a biggish cam or power adder.
Of course little cam = easy tuning.
30-40 yes.....which means on a mustang my numbers will be close. I would have at least gone with a scud at 219/223.
I would be shocked to see 30-40 from tubes and heads, especially without a substantial cam. the stock heads and shorties are pretty damn good. and I would think are adequate until you get into a biggish cam or power adder. If
a good set of heads will get you 30 on a stock 6.1. Curious who the builder is. BTW OP, did you get the cam used?
So.... have been trying to figure out what 426rwhp on a Mustang dyno = for crank HP.
When I asked the shop that did the dyno, they pulled off the computer that it equaled 530 crank HP.  That seems high.
Anyone feel like throwing their $.02 in?
