70challengerrt440
Rock Shafter Stabilizers
I'm a fan of the tower cross ties. But not a huge fan of the collars. I use the old 5.7 collar locators as they have significantly lower parasitic losses on the rocker.
I have been considering using these on my new build also. I like the ideal of the tower tie bars but not all that sure about how the collars would hold up in regularly driven street use.
Tell ya what......if I can get 10 people to buy 10 sets I would be willing to set up a group buy. How about $299.99 a set plus shipping?
Only if you'll post pictures of them installed.....
That'll take what?, 6-9 months. :P
Ever get the 10 people? I'm interested.
I'm interested also. Just need some $$. Some one please by some parts I have for sale
has anyone had issue with the material being softer than the rockers and getting ate up when they touch?
I always wondered if there would be any issues like that.
Not surprising. Two things to consider. The first one is growth of the sleeve. A assembly of the length can expand .010-.020 when it gets heated up. So too tight on the clearances and it'll die in short order. This was one of the issues with the Harland sharp POS's. The other problems is any burrs on the rocker will chew up the anodizing on the sleeve if the unit wasn't hard anodized properly. It's best to install a hardened thrust washer between the rocker and the sleeve if you have the room.
