Blue Blur
Walbro Gss340 Pump Enough For Stroker 6.1??
My car is a home built hot rod and when I first built the fuel system it was a mild BB with FAST EZ EFI and I installed an in tank Walbro 255LPH pump. The FAST ran with 43 psi with a regulator and worked good in that combo. I now have the stroked Gen III and use an LS filter/regulator which are typically 58psi. My injectors are 80lb Dekas, I know way bigger than needed, and it has worked fine until recently I have been seeing some lean shutdown from the ECU, which is a good thing that it shuts engine down from a lean condition, and its will sometimes backfire between 1st and 2nd shifts then intermittently lean out then as well like the pump shuts off then turns back on. Thinking about swapping to a Walbro 450 and also monitior fuel psi better. Havent been able to read data logs, and haven't been able to get it to act up when datalogging either with MS3 EFI. That's on me and I will get that figured out, probably need to get a memory card installed and do it that way.
You sure the pickup is staying submerged under acceleration? We run a stock 5.7 pump (280lph), factory regulator and factory 5/16 line and a 60 lb injector in the 440 and make a little over 600 at the tire running ms109 which is a much leaner burning fuel. We are consistent on A/F with no signs of pressure drop.
One thing I did change is I ran the return line to the surge tank instead of at the front of the tank where it was originally. Pump is in a surge tank with trap doors at rear of tank. I wonder if return line routing is causing aeration possibly? Have also read the relay setup that comes in the Efisource kit is iffy. Next step is mount relay at rear close to pump sttaight off battery. Seems like temp effects it as well. Really dont think its a fuel starvation problem since it always happens under acceleration high load and the tank is always half full or better.
