Chief 6.4
Current Drag Pak Engine Question:
Well any I suppose. My school is doing a Gen III project and we would like to add a drag pak cam to it.  We have a vvt block, but we have the capability to use a non vvt cam if needed.  ( we have an adapter)
What cam is used in the drag pak cars?  Any one have part numbers or a place where I can find specs?
5.7 & 6.1 both use same cam.
Camshaft P/N: P5153691
 Lift @ Lobe (max):   .365 inch         Intake:  .365 in         Exhaust:  .345 inch
 Lift @ Valve (max):  .584 inch         Intake:  .584 in         Exhaust:  .552 inch
 Advertised duration @.006 279 Int  285 Exh     Ground on 110 centers
 Rocker Arm Ratio: 1. 6
You don't know the duration at .050" by chance, do you?
not exactly but it will obviously be less  lol  ..... probably in the 230 range. someone with mad math skills could figure it out. not for my little pea brain.
That's what I was thinking, but was wondering if you knew. I'm not sure calculating it is possible, I think it would have to be measured as ramp speeds can be different from cam to cam.
