oilstrike
Fs Srt600
SOLD​ SRT600 & 3500!
Thanks to you all for the fellowship and help with my Challenger.  I still have the Enclosed trailer (equipped), Weld wheels, slicks, skinny's, header back exhaust system and other things that I'm sure to find.
Hello All,
I am selling my Car.  I am open to offers.
2008 Dodge Challenger SRT8 # 3824 of 6400.
Hennessey SRT600 #4 of 50 17000 Mi.
Brilliant Black Crystal Pearl, 6.1 HEMI, NAG1, UConnect, NAV, Moon Roof, Push Button Start
$74,749.00  SRT600 Hennessey Performance Engineering
Hennessey Performance Engineering converted it into their SRT600 #4 of 50.
• Stainless Steel 3 inch Exhaust System
• Hennessey Stainless Steel 1-7/8 inch Long Tube Headers
• High Flow Catalytic Converters
• K&N Air Filter, Diablo Sport Trinity T-1000 Tuner
• All Necessary Gaskets & Fluids
• Engine Management Calibration
• Professional Installation Vortech V-3 Centrifugal Supercharger System
• SRT600 Exterior Badging
• Serial Numbered Dash & Engine Compartment Plaques
• Hennessey Premium Instrument Cluster and Floor mats
• Chassis Dyno & Road Testing
• 1 Year / 12,000 Mile Limited Warranty
This car was purchased by a celebrity athlete (he signed the deck lid), who had it lowered 1 ½” to accommodate 22” MOZ wheels.  I purchased it and made the following MODS.
Paramount Performance
$3849 Paramount Stage 2 NAG1 70 Series
•· The Paramount NAG1 70 Series is recommended for LX/LC owners that make 700 ft-lb’s of
    torque or less.
•· Also recommended for SRT8 Jeeps at 625 ft-lb’s of torque or less.
•· This transmission is built with double sided AMG Mercedes clutches, Mercedes seals,
    Mercedes gaskets and Mercedes filter.
•· It has additional clutches in the problematic clutch packs as well as other proprietary
   internal modifications.
•· Shift firmness will be quite firm on the up shifts and down shifts.
$879.00 Dominator series Torque converter
Custom built new “Dominator series” Torque converter.  Extremely high stall speeds available for your NA Chryslers. Wonderful drivability on the street.  Unheard of ……Full warranty for 1 year, regardless of power applied.
These are custom built for your vehicle
$850.00 Paramount Performance TCM
* Specifically designed for use with the Paramount Stage II valve body.
* Shift points...6500 or 6800 or manual shift (custom available)
* Raised rev limit to 7300 (from 6767 stock and MTCM)
* Normal driving when in drive, autostick HOLD ON!
* Revised torque management
* Revised transmission pressures to augment our Stage II valve body.
$2150 LX/LC Unlimited HP Axles + Hubs
1,400 hp axles
1 year warranty to the original owner through DSS.
(No power limit)
High strength Chrome Moly steel (300m)
High strength hubs
$199.99 SFI 29.1 Certified Flex Plate (Hemi-NAG1)
Mandatory in NHRA & IHRA Class racing, this is a safety MUST.
Certified to 12,500 rpm Unheard of ……Full warranty for 1 year!
$129.99 Transmission Drive Shaft Loop Chrysler | Dodge
This driveshaft safety loop is custom-designed so that it can be installed in the modern Dodge Charger & Challenger applications with no modifications necessary.  Our loop can be installed without having to remove the driveshaft and is compatible with popular aftermarket exhaust systems.
$1599.99 DODGE 2009-2011 LC Challenger SRT8 Automatic Carbon Fiber 1-Piece Driveshaft
1350 u-joint  Custom 108mm CV with high speed boot and special grease
Spline made from 300m and installed into aluminum head for superior strength and light weight
Balanced on our high speed machine
Comes complete with all high grade hardware (not more bent Guibo bolts)
Rated for 1000hp +
1-year warranty.
25lbs
$5500 LX/LC 8.8 Rear Diff Assembly
3.06:1 OEM ratio, others available.
Heavy duty Limited Slip using a standard clutch style differential.
Complete assembly is painted black.
Unlimited HP axles & hubs are included.
Billet rear girdle cover.
Rear portion of your driveshaft will be modified to work properly with this diff
Petty’s Garage
$149 PG-TC-003
Petty's Garage Automatic Transmission Crossmember. A racers goal is to maintain the structural integrity of the vehicle while reducing overall weight. Replace your stock transmission crossmember with this bolt on replacement built by Petty's Garage. It is 3 lbs. lighter than the stock piece and maintains the structural integrity of your Challenger.
Carbon By Design
$1499.99 Dodge Challenger Hood
$1299.99 Dodge Challenger Deck Lid
$339.00 Dodge Challenger Radiator Cover
$374.99 Dodge Challenger Deck Lid Spoiler
Seibon Carbon Fiber $978.99 2008-2011 Dodge Challenger Seibon OEM Carbon Fiber Side Skirts $858.00 Rear Bumper Cover Replacement | Carbon Fiber Rear Lower Valence panel $1040.00 2008 Seibon Carbon OEM Grille Surround facia $105.49 08-2008 Dodge Challenger Carbon Fiber OEM Style Front Canards $945.45 OEM-style carbon fiber tail light surround for 2008 Dodge Challenger
Race Ready
$845.00 3” Electric Remote Open and Close Exhaust Cutouts
Black Ops Customs
$2800.00 Black Ops one off, Carbon Fiber seat rail side covers R & L
ORS Body Shop
$7500.00 ORS Professional installation and paint work and installed
other special order and one off items, for which I have not yet found the receipts.
VIPER Alarm Remote Start 5904
$782.94 Purchased from and installed by Best Buy.
HOOSIER 17X10.5X30 SLICKS​
$225.00 X 4, $1000.00
M&H  Racemaster 4.5/26.0-17 D.O.T. Front Runner Tire​ X 2
$363.00​
WELD RACING​ 17X19 CHALLENGER SRT8 BLACK CENTER POLISHED WHEEL
$489.00 ea X 2 $978,00​
17X5 WELD RACING 17X5 CHALLENGER SRT8 BLACK CENTER POLISHED WHEEL
$465.00 ea X2  $930.00​​​ ​
                                                  SRT600 TOTAL     $111,839.81                                                      ​
                                                             Package Price        $83,000.00
Might I suggest separate pricing for all three, along with a package price.
Chances of finding someone interested in all three are going to be slim.
Good luck. Nice trailer.
Man,I hate to see this. Hope everything is well, Johnny. Didn't realize it was Tim Duncan's car. I do know this setup is top notch, and frankly, Johnny is a bigger superstar in our community!
Sorry to hear about the sale. Hopefully it is just to get a newer toy. Was good seeing you at the Mopar Nats this summer. Love the carbon fiber stuff lol
GLWS
I'm not sure that I have the actual receipts, but spending the money is burned into my memory...
Johnny your supposed to throw away the receipts. GLWS
Thanks for the kind thoughts.  I'm not sure what the future holds.  This would be one great Christmas Present!
I bought them for each other, it wouldn't be right to separate them.  Thanks for the suggestion.
Regards, Johnnie
Your one of the reasons I go to cf. just to hang out with ya. Your a cool dude Johnny and I'll miss ya. Good luck buddy
Same here Kev, and thanks
Johnny will be fine to come to cf7 he has a 2011 300 c......you know, just like the site modern mopar all invited; )
GLWTS Johnny
I've let some people know a good deal is to be had!
Linda :)
The 17x5 weld front runners you wanna sell those separate?
If I don't sell the SRT600 I'll need to keep them.  So they will go with the car.  Thanks for your interest.
Regards,
Johnnie
GLWTS Johnny
Linda :)
Thanks Linda, You are correct, even if I sell the SRT600 I will still have a couple Mopars'.
Johnnie
Hate to see this!  Always a pleasure talking to you at CF.  I hope you come if just to hang out.
Thanks Speedy, I've always enjoyed the fellowship, which is a good thing since hanging out isn't frustrating (unlike trying to make it from A to B without breaking something).
