Bruce*
Whippled 06 300C Srt8
82 posts in this topic
The plastic idler pulley adjacent to the water pump pulley is too narrow.  I ordered a dayco steel pulley that's almost twice as wide and about the same circumference.  I am also using the GT 500 tensioner with the adapter plate.  That combo seems to be working pretty good.  I'm not sure why the ARS tensioner did not work as well for me.  Those tensioners (street and race version) have significant more spring pressure, so I can't explain the better results with the GT 500.
Bruce
Going to upgrade from a 6 rib to a 8 rib setup. Hoping that will cure some of my issues ( snapping belts and tensioner bouncing). I also recently increased the size of some of the idler pulleys to give me more belt wrap. Would like to make it to the track soon to see if I can pull off a 10.5 sec run.
Relocated my belt tensioner to the upper passenger side of the block and it’s bolted to the bracket in the original location that the adjustable idler pulley was located  Added 3 idler pulleys: between the crank and alternator, between the wp and ps pulley, and one just above the ac pulley  Now all the major pulleys have at least 50% belt wrap.  There should be no more belt slipping  Also went from a 6 rib to 8 rib setup.  The tensioner is from a 5.7 hemi and the reason we used that is because it applies tension in the opposite direction, as opposed to the others ( GT 500 and ARS) I’ve used.  Hoping I can put this issue to rest once and for all.
Trying to see if I can post a pic.
