Chief 6.4
Guys I Need Some Good Help/advice. Please!
Okay, The project is a 68 Charger and there is a 6.4 short block sitting on a stand for it.  If I wanted to use the msd ignition system I know the crank reluctor wheel will not work. Could I use a reluctor wheel from a 5.7 or 6.1 on the 6.4 crank?  Thanks for any help!
You can't select the tooth count on the MSD box? I know Lingenfelter used to sell a module that converted 58x to 36x tooth signal for swapping LS3 engines into older bodies. Should work for the hemi.
Sent from my SM-G920V using Tapatalk
