R/T Rick
392 Gears
Can you just buy the ring and pinion gear set and have them installed in to your factory rearend on a 2011 challenger?
Thanks
There are shims that aren't readily available so it's not just a bolt them in swap, I would highly recommend having Erik @BFNY set them up for you if you want it done right, Probly cheaper to buy a complete new 3.92 diff though.
