SRTgreasemonkey
Tial Bov - Mounting Suggestions?
how many of you are running Tial Q?
and will it be possible to mount it in the same location as the crappy stock Procharger one.
I assume I'm gonna have to weld a new flange in lieu of the existing one due to the bigger size.
anybody have other suggestions or pictures I could use for reference? probably going to try to install this weekend (1-20-17) while my cage is being welded in.
I'll dig up some pictures of a couple I've done. The biggest key to success is setting up the vacuum signal properly. I make a vacuum manifold then -4 line to them. Also if memory serves me correctly you'll need the pink spring too.
thanks Cam! i picked one up with the -2 SC spring, should be on my door step friday hopefully.
it comes with a nipple to mount to the top of the unit, i assumed thats where i attached the vac line. am i missing something?
Yup. You'll need to get the adapter if you want to use AN fittings. I got one in the shop, I'll get you a part number. If you don't want to go AN at least run a good quality 1/4 or 5/16 vacuum hose and don't use any of that cheap shit. A accurate vacuum signal is vital to these working well.
