06hotrod
Sold !!!2006 Dodge Charger / Approximately 3165 Lbs / No Cage
Work done by myself and Truestreet Performance – Tune by AJ Hemituner
Probably $15000 in parts not counting the car. Want $8000
I DO NOT WANT TO PART OUT AT THIS TIME, DO NOT ASK. If I do I will update post.
Drag pack intake
Accel 1300 cfm TB
Paramount Trans installed…………Feb 2012
TCE 15” brakes front and rear…..Sept 2013
Paramount 8.8 (3.55)…………………Sept 2014
DSS CF driveshaft and  1400 Hp Axles…….Sept 2014
BFNY Solid bushings……………………………………Sept 2014
Danko fiberglass fenders, upper and lower grill, V2 rear spoiler
Carbon by Design CF/Fiberglass Trunk lid
VFN 6 pack Hood….Special order 5” tall scoop with Danko honeycomb insert to match grill
Speed logix Front cradle, Solid mounts, Trans mount, Bumper support, Billet upper control arms
Stage 6  Two step,  Wired up but disconnected when car stripped
Trans cooler
Corsa Extreme / no cats, spread to clear CF driveshaft……2010
Kooks headers
Moroso   Coolant, power steering and oil pan
Billet Technology  Water neck, Dipstick, Oil cap, Shift insert and Valve covers, the only set they made like this as far as I know.
Antigravity Lithium Battery  5.5 lbs…….$450
Magna Fuel  Pump, Filters and regulator  +++ Fittings, Teflon hose, RCI 5 gal tank……Approx. $2400 in parts
Battery shut off + new 1/0, 8 and 4 gage lines to fuse block and charging posts. Wire was over $300
Optic Armor rear and door glass.$520
RPM Rear seat firewall
Spohn Rear adjustable control arms…$592
Chassis Engineering  Door handles
CX Racing Coil overs with adjustable damping
Weld Racing  15” RTS wheels with Hoosier 26.0/4.5-15 Drag Front Runner  and Hoosier 28.0/10.0-15 D06 Drag Slick. Maybe 20 runs
Stock hood, trunk and fenders
Innovate AFR DB-Blue Gauge / LC-1 Kit - P/N: 3795
Kirkey 18in Layback Drag seat
5 Point harness – Expired : (
Line lock
http://s215.photobucket.com/user/350hpv8/slideshow/06%20HotRod
lol, not quite but yea a really good deal for someone who has the space and maybe a good motor to drop in.
8k that shits free.  what paramount trans is in it?
Good luck with sale.  Nice start for a stout race car.
If you part out give me a call.  I want a few of those items.
What in the world could you want from MY car????
