UpInSmoke
Lowering The Seat Mounting Position???? Possible??
Not sure if this is even possible. So Im 6'3" & Ive got a 2014 300 SRT with the sun roof & I'd like to know if there is a lower/shorter seat bracket so I can get some more head room. Has anyone done something like this or has anyone thats pulled the seats is the even room for seat to mount lower? Hell even an inch would be great
The motors are tight to the carpet at the lowered position so unless you went to a manual slider I doubt you'll be able to get anything out of it. Probably you're best bet would be to have the seat cushion modified. Btw, I've done several of the remove the seat and add the kirky seat to the track system mod ;)
Hey Cam... Any pics?? I have a Kirkey seat hanging from the wall in my garage that I've never mounted.
Maybe but considering I've had a couple puter melts downs over the years it's take some searching. I think oneluv has some in his thread about that build on LX. I'm supposed to be working right now so I'll need to look later on my old drives ;)
Thanks Cam!
Give Micah a shout for Kirkey seat mounting systems. He uses a custom fixed or slider system and aluminum side mounts.
Thanks Mike.  I'll send him a message to see what he has.
