G Funk
Kenne Belle Catch Can = Fail
Guys, what are you all using for your catch can with the Kenne Belle?  I was using the small plastic one that comes with the kit but 1) i have to dump it out every couple of days (daily driver) and 2) last night it came out of one side of the mounting bracket and rubbed against a pulley and it dammmnn near sliced right through the plastic and some oil did end up leaking out over night but not much.
I need some better ideas for a catch can than this plastic one, instead of ordering a replacement plastic OEM kenne bell i would like to patch mine up and order something better.
Unless I'm mistaken there's no reason you can't use a standard catch can. You will have to make up your own hoses though.
I prefer to use the Moroso catch can for both looks and price.
Not sure I would run it back into the pan.... like the on in the link.
Yeah i don't do that :)  I just keep topping the oil off as needed and i'll change every 5k miles.
Thats the one man thanks!  Thats the mounting bracket i need too, i was going to rig something like this up this weekend but i'll just order this one.
Can you just get rid of the kb can and use a different one mounted somewhere else?
That is what i was leaning towards, so yeah.  I'll post a pic once im done :)
Let me know if you need help finding the right one. I can also drop shop the kit to you if needed!
I ordered it before i saw this, sorry.  I am about to hit you all up for remote tuning though :)
I have a allstar catch can. Both valve covers are vented to the can. Works well for me. Just had to make a bracket for it. 060fe844cff6c16c123d0df61876e986.jpg
Sent from my SM-G930V using Tapatalk
