Rat Patrol
Last Minute Bolt On - Possible?
Up till now I had intended to rebuild my 6.1 with just the cam Ive bern running, PSI2511 valve springs already installed and forged pistons to rectify the cam position .
The comp would remain at the factory 10.2:1.
If I run forged pistons, 6.1 rods and forged crank, at 10.2:1 compression.....
Would I be safe with 8psi boost through a Vortec or Procharger.?
Or will I face priblems with the compression and blow gaskets, bend rods or destroy bearings?
Likewise...can I use my existing 110 LSA cam....or would I need to swap it out?
Im only looking at mild boost...to get motor over 500fwhp.
Compression is fine
Lsa will be tuff on a blower car
Mine is 113 and was hard to get a happy tune
So keep that in mind
Plus you will loose some power with that one in.
The information from us1champ and nascarpat24 is as accurate as you will find. We have Non-VVT blower cams for just such applications with 116 LSA. Let me know if your interested in purchasing one.
