steveneth
1000+ Rwhp Challenger Rt
27 posts in this topic
Hello all, I just wanted to see what you folks thought of my build.
2013 Challenger Redline RT
392 Stroker built by TyTech
Manly forged rotating assembly
Methanol Injection
Precision Turbo Twin 67/66s
NAG-1 1000HP Transmission from Paramount Performance with custom TCM
Headers and full Magnaflow exhaust
Loudvalves boost controlled cut-outs
Custom Triumph Forged 20x9.5" front and 20x11" rear wheels
Nitto 555 G2 265/35/20 fronts and 315/35/20 rears
Powerstop brakes
Eibach Pro Kit
RGV Pro Lighting Headlights
1036 RWHP / 978 TRQ at 20 PSI on pump gas
Built by DBR High Performance
Check it out at SMOKD_RT on Instagram
Looks clean. I dig the stance. If you took it to DBR you must be local to me? Definitely wanna check it out at CF8.
I'm close to Nashville.
Yes they are boost activated. Open at around 5psi. If you look at DBR's FB page they did some before and after dyno pulls on a mustang and an SRT jeep and made some impressive gains. You can also connect them to a boost controller and make them open at a higher psi. I like the fact that they allow me to cruise around and sound basically stock but at WOT it sounds like the wrath of God is coming!!
I need some advice. This car still needs a driveshaft, rear end and axle upgrade. I have looked at a 9" "bolt on" kit but dang $9K!! Anyone know of a cheaper option? At this point one launch on a drag strip and something is going to snap!!
The DSS 9" or Dynatrack Dana 60 is the way to go. We have installed both and have thoroughly tested the 9" and will be doing some high horsepower testing on the Dana in the next few days.
The DSS kit is actually $7200 if ordered with the LSD. With a spool it's $6800 or so. It's expensive but it's extremely stout and won't break at your power level!
Thanks, I'll definitely look into that.
