manofsteel06
2016 Challenger Scat Pack/ Hellcat Rear Cradle Swap
I have a complete rear cradle swap out of a 2016 challenger scat pack.these cars share the similar suspension as the hellcats.it's equipped with the popular 3.09 rear gear that is a upgrade for the hellcats.I am selling it complete with shocks,control arms,springs,230m axles,zf differential (stronger then the getrag)spindles,hubs.this unit only has 4,000 miles.asking 2500 plus shipping. Can text me at 313 926-1568
Not the same as the Hellcat. The springs and shocks are different than on the Scat Pack. The Hellcat has the Active damping suspension that is adjustable. Good price for the axles and Differential. Those are expensive pieces to purchase.
"The Active Damping Control Module (ADCM) controls the suspension and ride for the SRT version of this vehicle by adjusting the rebound and jounce of the shock assemblies using the above information and predetermined settings for maximum vehicle control. The shock absorbers are unique to the Active Damping System (ADS). Each shock absorber has a valving unit that is external, but still part of the shock absorber. Inside each valving unit are two solenoids that control the damping valves to alter the ride of the vehicle. The shocks are replaced as an assembly, they cannot be disassembled for repair. "
Yes this is true the shocks and springs are different.most people that are doing the swap in the earlier lx models,are not able to use the adjustable shocks. Plus this comes with spindles,hubs,control arms that are included. I have everything to swap into the earlier models.only thing you need to use is your existing sensors.
