jefe
Blown Motor
I have a 2011 Ram 1500, it has the 5.7 and most likely have to rebuild the motor. If that is the case, id like to increase the performance of the truck. I dont have that much knowledge on these motors or even how much you can increase the bore or stroke and so on. Is it possible increase the bore, stroke and would i need a different crank shaft or should i get one just because.
Welcome to MMF. You can go mild to wild and a lot depends on what you can or can't do yourself.
Work with a vendor like BFNY, Arrington, A2speed or HHP and see what they can do for you.
Where are you located?
Nepa
now how much do the motors in the trucks and cars differ, because that would also make shopping for parts easier if they were
