mopar27028
can't improve 60 foot times...
A8 Scat with Maggie making 675hp 650lb/ft. My local track is 1/8mile, last fall in good air my best time was 7.208 @ 104.4mph with a 1.766 60 foot using 20" Nitto radials.  I thought i would get some real improvement this year when i went to 17x10 welds with 295/45's M/T Street Strip with 17" front runners, but I've yet to get a 60foot better than 1.74X.  Max torque is at 4260rpm, is a higher stall converter my only option to get this boat moving and improve my 60foot and et?
roll through the waterbox , burnout in 2nd gear  4500rom for about 5seconds using the line lock on tazer.  stage then bring rpm up to 1500-1800, release the brake once the car starts to move i steadily roll into the throttle.
Like Tiger said just hammer it I get below 1.7 once in awhile with stalling it and just punching it out of the hole with slicks
Sent from my SAMSUNG-SM-G935A using Tapatalk
My local track doesn't do a great job of prepping for test n tune so she spins if i hammer it out of the hole.  At a track with good prep I've wheel hopped horribly on a couple of occasions when being more aggressive.   Holiday weekend hoping track prep is good tonight, i'll be more aggressive on every pass and see if i can find a happy spot.
Hoosier slicks.  I got high 1.5 60s pretty consistently on the old car.  Anxious to try them out on Go Man Go as soon as I figure out a drive shaft solution.
Drag radials need a pretty dialed suspension IMO, especially with a 2 ton tank and marginal track prep. Demon owners are going to find this out really quick. Slicks just work better in this scenario.
I changed to 305/45 ET StreetR and have gotten a few 1.688-1.690 at my crappy prep local track.  ZMax is suppose to be open for this Friday, two lanes no prep and two lanes prepped... if I can't get consistent low 1.6 times I'm going to look at suspension work.
I'm sure slicks would give better more consistent results, but i've got some serious back issues  and I don't want to be changing tires at the track and have something happen.
Did you ever get the 60' down with your power and the same tires as me and. I hammer it out of the hole no issues with traction for me. ddf120a59ec7707de1c18454077ec8d9.jpg46dd0d7a673458baff8f7b22706efbad.jpg
Sent from my SM-N920T using Tapatalk
