Opinions on a camshaft for a turbo setup?
So I'm switching builds with my 426 stroker. I'm dropping the compression to 10:1 and plan on doing a promod 88 front mount. Depending on power levels, I might spray a 100shot through my direct port setup as well.
I will be using e85/e98
At the moment I still have 3.06 gearing and a 3400 stall.
I street more then track, so I'm sure I will still be doing rolls just as much as digs.
Let me know if there is an in house cam or custom grind you would recomend
Sent from my SM-G955U using Tapatalk
