Bruce*
Solution for 8.8 spewing diff fluid
Ever since the install of the 8.8 I've had issues with diff fluid spewing all underneath the rear of my car.  I had Erik change out my gears a year ago and I finally got around to changing the fluid for the first time.  When I drained the fluid there was about  1 quart that came out.  It should hold 1.8 quarts, so after about 3000 miles I lost almost a quart of fluid.  I looked around on the internet and found a possible solution.  I used an inline fuel filter and installed  it backwards on the end of the vent hose.  I cut about half the hose off so the filter would be sitting vertical and any fluid that is trapped in the filter can drain back into the housing.  I just put this on not to long ago, so we'll see how it works.  I know some people use a catch can, but this will be much better if it works.
Captalbator (he is on this forum) had the very same problem with his 8.8 diff. Pm him.... he will be happy to give you his solution to this annoying problem.
The real solution is to prevent the turning oil inside from rushing under the deflector plate and try to get out. With just a little gasket applied at the right spot inside around the deflector, you can do that. My catch can is always empty since then and the air can still go in and out without problem.
