CruzKing
rear shock replacement
I was told that to replace rear shocks on a challenger you have to drop the subframe. Is that the case. one youtube video shows a guy take out the old shock in 5 minutes.
 video below:
http://video.search.yahoo.com/yhs/search?fr=yhs-iry-fullyhosted_003&hsimp=yhs-fullyhosted_003&hspart=iry&p=replace+a+charger+rear+shock#id=1&vid=da4040b492bd511b6146a9e42667f3d6&action=click
Shocks are an easy replacement, the cradle does NOT need to be dropped.
If installing coilovers, you must remove the factoy springs, which DOES trquire dropping the cradles just enough to slide the springs out.  Then installing the coilovers is easy.
