sinmiedo
Drop in fuel pump recommendation
Looking to get rid of boost a pump on my 09 Challenger SRT8 Procharged P1SC1 stage 2, 7 psi stock block. I've seen the API and MMX fuel pumps. Any pros or cons? What are others using? Is new tune needed? Thanks.
I've got the API pump in my car. Super simple to install, drop in and go with a little wire cutting if I remember right.
Sent from my SAMSUNG-SM-G935A using Tapatalk
I just use an AEM 50-1000 fuel pump on my 6.1 D1SC setup. $100. I had Modern Muscle Performance install the line and quick connect fittings on it for a little more.
Sent from my SM-G950U1 using Tapatalk
