steveneth
Traction
HELP!!!!
Took the car to the track on Friday. 17” welds with M/T ET street Rs on the back. 305 wide. With the two step set at 1700rpm I could launch well but halfway down the track they would break loose. Basically when the boost would come on. I had the boost turned down to 10-11psi so about 750-800hp to the wheels. I kept turning the boost down and still could not keep traction. I ran the tires at 25,20 and 18 psi. Nothing helped. I have an 8.8” rear end, 3.55 gears and 1400hp axles. Still has the IRS and I have the Eibach pro-kit springs. What do I need to do in order to keep traction. This car should be way faster than 7.15 @ 97mph.
