asianANDY
Rossler TH400
I have a Rossler th400 w/trans brake built with big drum. Reverse valve body, Reid sfi case and bell housing, lokar dipstick tube and plug. Protorque converter. ATI crank adapter, spacer, flex plate and overflow tank. Precision Shaft Technologies cf driveshaft(promod strength). Custom built cross member with drive shaft loop and trans mount by true street performance. Excellent shape, frequent oil changes. Trans came out of buckeyeguys magnum and not have been used since. I'll take $4900 shipped to the lower 48 plus PayPal fees.
Per my conversation with Guy; this trans should withstand 800-900hp conservatively. Anything above that, a harden input shaft is recommended. I wouldn't be hesitant putting it behind a 1000hp turbo setup as the launches I believe do not shock the powertrain as hard but I could be wrong. Anyways, anything under 1000hp this trans should be bulletproof.
