YLWJKT
Fore Dual Fuel Pump & FC2.
New in box, with FC2 Controller.
Fits 2011 and up Challenger and Charger, including Hellcat.
NOTE: Hellcat will need additonal fuel rails and line, available directly from Fore.
Retail is $844.00
Will take $700.00 shipped.
From the Fore website:
Fits 2005+ LX, LC, LD
Double pump module
Supports 1200+ rwhp
Use with OEM fuel feed line or upgraded fuel lines
Use in return or returnless configuration
E85 and race fuel compatible (see pump manufacturer recommendations on fuel compatibility)
O-ring feed and return ports (may be plugged for returnless operation)
Multiple fuel pump options to accommodate 1200+ rwhp
NEW Anodized black for maximum corrosion resistance
NEW Polymer pump support minimizes pump noise and eliminates electrolysis
NEW Dissimilar pump compatible to minimize fuel heat while retaining maximum performance
BEST POSSIBLE VEHICLE INTEGRATION
No permanent modifications necessary to vehicle
Hermetic wire pass through, absolutely no chance for fuel smells/leaks
OEM level sender retains original position and orientation
Retains complete capacity of fuel system, even at low fuel levels
