MoparMarty504
Looking TO Buy 6.1 Intake
Dodge Challenger Cat Back Exhaust System - 6.1L
6.1L - '08-'10 - A Dodge Challenger Cat Back Exhaust System is a relatively simple power modification that will free up your Challenger's exhaust gas flow and produce an engine note that is more pronounced than your stock muffler. Adding a Cat Back Exhaust can provide several benefits, the first of which is more power. This Dodge Challenger Cat Back Exhaust System is designed to be freer flowing than your stock exhaust, incorporating larger diameter piping and higher-grade mandrel bent tubing for a more laminar flow. These changes can result in a reduced level of back pressure at the engine manifold, which means the engine can breathe a little easier and release more horsepower and torque. There is also an increase in fuel economy after installing a Cat Back Exhaust System. Another big benefit of a Cat Back Exhaust System is the sound they can produce. From a little more grunt to a full-on growl, you'll definitely notice the difference in your Challenger's sound after installing this Exhaust System.
  • Performance Cat Back Exhaust
  • 6.1L Engine
  • 2008 - 2010
  • RSC no-drone technology
  • 2.75-inch 304L stainless steel mandrel-bent tubing
  • Stainless (Torca) clamps
  • Polished 4-inch Pro-Series tips
