silverfish
Rear diff swap on '10 Challenger R/T
I realize there is a lot of info on this if you search the forum but I haven't been able to find any direct answers, lots of conflicting info. Here is the situation...I have a 2010 Challenger R/T Classic Auto so it has an open diff with 3.06 gears.  I have been wanting to change it do a limited slip diff for a long time and the other day I ran across a good deal on a used one on ebay so I bought it.  It was advertised that it came out of a 2012 Challenger R/T.  There was no VIN on the ebay ad.  I got the diff the other day and it had a tag attached to it with the VIN and its from a 2012 Challenger SXT Plus according to the VIN.  I decoded the VIN and it does say it came with 3.06 gears but I can't find anything that says if it's limited slip or not.  There is no tag with a part number on the diff.  There are numbers stamped on it in a couple places but none of the numbers match up to any part numbers I've seen for diffs.  I'm just trying to find out exactly what I have so I know if it's limited slip or not and if it will work in my car or not.  Can someone look at these pics and tell me what diff this is.  If not can anyone direct me to a source that can tell me?  Any info is greatly appreciated!
i have an 09 challenger, but always used 08 thru 2010 diffs/axles. i think 2012 was different. maybe someone can confirm it.
 To me it doesn't sound good, someone else chime  in.
You do know you need axles with a LSD right.
Yes I know I will have to have different axles.  Just don't want to move forward unless I know this diff will bolt up and that it is limited slip.  When I google the number stamped on it all I come up with is Mercedes Benz stuff.  I just bought this one because it was pretty cheap and it said it was limited slip and said it would fit.  I may have been better off spending more money or waiting till a decent deal came along on a getrag that fits a 09-10 model.
I buy used srt diffs for $300 , and buy a spare when a deal comes up.
But let me say this, when stock my 09 left rubber always with the open diff. i really didn't need to upgrade untill the supercharger. good luck, and let us know what you find out.
Ps the wife had a 2012 charger maxie and didn't have the LSD.
I'm in the same boat, it was fine when it was stock but now it has a D1 Procharger on it.  I haven't seen a used srt diff for $300 or believe me I would've bought that instead.  I may just need to resell this one if I can and find a srt getrag diff instead that I know will work!
Update:  I checked the diff that came in my car from the factory and it looks exactly like this one that I bought.  It even has the same numbers cast into the side of the case.  Called the place I bought it from and they agreed to refund my money on it since it's apparently not a limited slip differential.  Guess I'll be on the hunt for another one now and will make sure I see actual pics before I buy this time!
Yeah I was about to post the bad news, glad they are refunding you. Keep an eye out for deals on the forums and EBay...best bet is like G said and hit the yards. I’m in the same boat needing to upgrade too. Stupid Mopar using an open diff in an RT just because its auto!!???!!! It’s the faster of the two tranny options for crying out loud.
Agreed.  Pretty dumb.  I honestly never realized it until I put the Procharger on it.  And it's not like I ever race it or anything like that so it's really still not that big of a deal.  I just don't like the fact that it's like that so I want to change it lol.
37 minutes ago, StevoHemi said:
I have the exact same car as you Silverfish. I had the 3.06 gears swapped out for 3.55's plus a Wavetrac installed.
http://wavetrac.net/
Still have the stock axles and driveshaft.
This mod really woke her up.
I've seen that setup advertised a couple times but have never talked to anyone that had actually done it.  Good to know you like it.  Have you put many miles on it yet?  Does it make any weird noises?
I should clarify.... I am still driving with stock axles and driveshaft on the car ..... no problems yet. I am upgrading to a DSS Aluminum driveshaft this year.
I have pretty much decided not to track the car anymore. I just wanna drive it....
 wtf, cluck cluck cluck.:o
So I got the right info on this, you had the wavetrac installed along with the 3:55 into the stock housing ( 3:06 open diff )?
I need to check into this, I was under the impression there were no upgrades for a direct swap with the stock rear for us Auto  owners.
Correct.....
Correct.....
I did the wavetrac as well, stayed with 3.06, once upon a time. The key is finding someone who knows what the hell they are doing. Wavetrac installs are not for the faint of heart on the open diff.
The Mexican did mine..... God bless him....
He most assuredly knows what he is doing. Mine had the backlash a little out of spec and it ate itself up. Was great while it lasted!
So far a 50/50 review! One of those things that make you go Hmmm
I liked mine, the problem was with the install not the wavetrac. It held 500+whp just fine.
