Bright White R/T
Siphoning Fluid from Clutch Slave Cylinder
I'm needing to flush my clutch/brake fluid as my clutch pedal gets soft when running at the track making it difficult to shift....
Draining the master cylinder reservoir is pretty straight forward...... does anyone have any tricks or recommendations for siphoning the brake fluid out of the slave cylinder without having to separate the trans from the engine to compress the slave cylinder....
thanks-
rich
