codylozano11
th400 swap
I just wanted to make sure I'm covering all the bases with this swap into my 2013 Charger RT
AJ is already working his magic on my PCM
From the information I found. The starter i need for the swap is Mopar Part#05030023AA
I have a "level 5" t400 from FTI with a Reid case and a Gen3 specific Reid bellhousing as well as a convertor from FTI
Ratchet shifter from B&M
custom CF driveshaft for a th400 to DSS Ford 9"
I understand the trans tunnel needs to be tweaked a bit too
Most of the information I found about this swap on the forums is pretty outdated as far as the post goes and their all in regards to pre-2011 gen Chargers. I wanted to make sure I didn't overlook any important details.
As far as the Gen3 specific Reid bell goes. Does this still require a GM transmission adapter? From the impression i got after speaking with the guys at ATI is if I went with a standard GM convertor & bellhousing the Adapter kit is necessary. But if i went with the Reid specific Bell and a GM convertor that has a certain shorter cover. The adapter kit isn't necessary?
