blackcharger1
cam upgrade to factory 6.4 VVT
Do more research, you will find the 6.4 cam in the 5.7 has terrible reviews for the most part from those that actually race, instead of those that brag about racing
Contact a builder and have them select the right cam for your needs. More bang for the buck and better results.
Don't forget springs... push rods and 6.1 lifters.... maybe also upgrade to a larger TB to compliment the cam.
    The torque range has changed with the 392 cam.Peak torque is higher in the rpm change now. Making more power just higher in the rpm's. You will probably have to go with a higher stall convertor to get the benefit from the new cam. I am in the same boat. New cam back in April now slower at the track. I currently have a FTI 3200 stall.  I am going to have to go to at least a 4200 stall to be in my cam peak torque range. I will get it dialed by in & be faster in the long run.
^^^^exactly. Back when we were putting the 392 cam in the cars there wasn’t anywhere near the VVT cam choices or the tuning to support cam changes. This was 2011-2012ish. We have come a long way since then. Any can change is going to require supporting mods to go with it, and the converter is one that is often overlooked by a lot of the guys with automatic trans.
   My 60ft times went from mid 1.5s-1.6 to 2.0. After I get out past the 100ft mark the car feels like you hit it with a shot of nitros. Off the line is probably where Cruz King's car got slower with the new cam. I am not sure about the cam specs on the 392 cam but I remember them being quite a bit different from stock 5.7 cam.
It is, it’s larger with a really wide LSA. Mine was a dog off the line after the swap. Lots of 13 second passes at 117 and 2.0-2.2 60’s. lol.
Custom grind from a builder.... my custom blower cam gave me 80 hp......
Drop the 392 cam idea like the plague....
Add a 90mm TB to compliment the cam....
yeah what he said,^^^ even can see the drop in tq on my dyno chart down low, and that's where you do your daily driving, so it really sucked. Work was done at Arrington with AJ doing the tune. He really helped me out after a month later when i wanted to go back to stock cam. yes it was that bad.
same here.
