Hemi57
USB Ports In Op
Parked the car as usual and upon restart, the car wouldn't shift out of 1st gear plus the USB port with my attached thumb drive didn't restart. Got a  Msg. "Connect USB device". I stopped, shifted to park, turned off the car, restarted the car and the shift problem was gone. But, no USB. No thumb drive or Android Auto off the other USB port.
I tried to reset Uconnect via the press/hold the upper right corner. That did not fix the problem. Next, I pulled fuses 37 (radio) and 38 (media center) in the trunk fuse panel. This resulted in a blue background base radio setup and restarted with no volume, no Sirius XM and no GPS. But, it did show USB with the last song being played. Uconnect showed a Chrysler logo on shutdown.
I did another Uconnect reset and everything returned to normal.
