camarochevy1970
Catch Cans, Throttle Sensativity And Spring
Guys, looking to add a catch can to my srt in spring. Is BT the only folks that make them? If so, do they still have an issue with the lines leaking?
Also, has anyone else noticed that when you hold your throttle at a steady state, saying trying to rev the motor at 1000 rpm, that the engine speed continues to climb?
There are several CC available. A lot of guys like the Moroso as it has a drain line. Stack Performance has their own as well.
Keep in mind that Pedal Position and Throttle Position are two different things. You enter your request at the Pedal and Hal makes his own decision from that. I know I can hold an RPM at the pedal fine.
