Hemi57
MOPAR ABS Cover
Not sure where I snagged this part #... as I usually like to credit the person that found it
or at least the thread that I found it in.
Part # 68272122AA (Might be a Hellcat part)
eBay - Original Autoparts Express 2 - $36.39 Shipped
Before
After
2017%20scat%20pack%20abs%20cover%2002.jp
What's In the Package
2017%20scat%20pack%20abs%20cover%2000.jp
INSTALL
Remove the Fuse box cover and flip over the Windshield washer cover for better access.
Next slide the ABS Cover tabs into the slots in the grill support and mate up the 2 mounting
holes on the fuse box. I use 2 plastic screw type scrivets to hold don the ABS Cover.
2017%20scat%20pack%20abs%20cover%2001.jp
Now re-install the Fuse Box cover and you're done.
8 hours ago, Sybil said:
Nice piece I may have to get that if it will fit my car. Looks like it will or can be made to fit.
Sort of.
16 hours ago, us1champ said:
You have to cut down the tabs to fit on the older cars. I tried
Tried and succeeded?
I actually had to trim the tabs a bit. It fit but, it was putting a lot of pressure on the tabs.
