CenTxRT
Spark plug recommendation
I am running a 12.5:1 compression 5.7 hemi stroker built by BES.  Naturally aspirated. Running on 110 octane race fuel.
In the past I've run a Brisk ER12S spark plug.  I was wondering if you had any other recommendations for this heat range.
Thanks!
Won a head package done by BES in 2013 by coming in 2nd at MoparFest at Beech Bend.
5.7 Hemi Stroker by BES through you guys. 414 ci.
12.5:1 compression
Naturally aspirated
Pro Systems carb
PTC converter
Put it all in a 1970 Duster.  Does this ring a bell?
3 hours ago, funkpolice said:
  that link said $43.00 for a set of 16.  $700.00 worth is a whole lotta plugs.
(In my best Emily Litella): Oh. Well. That's completely different.  Never mind.  This would be a good deal if they could last at least half a season.
It's the price you pay for having 2 plugs per cylinder. Back in the day, you could go thru a set per race day. Racing ain't cheap!
Hate to say this but this reminds me of my RV customers... 150 to 200 large for an RV and then bitch about a $50 fuel filter adapter. Converted a $90 1 off fuel filter to use a $10 one you can get at any auto parts store.
The Brisks are holding up fine 2 or 3 full seasons!  I pull them and all they need is a little cleaning.  The gap has barely changed on them!
I don't mind $11.00 per plug if they will last 3 years or better!
what plugs are 2 colder from stock in copper?  would love to buy a set for 43 vs 180.  have some dyno tuning to do in a bit over a week or so.  big power bge heads, 411 9.75:1 twins e85 holley efi
On 6/19/2019 at 9:38 AM, HighHorseman said:
If you're changing plugs regularly then the coppers are a great way to go:
https://www.highhorseperformance.com/NGK4306_p/4306.htm
Sorry, wrong heat range.  These appear to be for a hemi with a standard compression ratio.
the #12 heat range in Brisk would correlate to an NGK plug with a heat range of 8.  Do you have anything like that?
