R/Thawk
6.4 cam on a 5.7
Hello to all and anyone that can give me any help or information lately I've been thinking about camming my 2013 Dodge Charger with a 6.4 cam... but of course I don't know what all I need to change out I've been told by some people that I can just put the cam in by itself and to get a tune
Nope.... nope.... nope..... don't do it. Lots of threads on this swap. You are better off to contact Eric at BFNY or Mike at OST..... they will pick the cam you are looking for.
Did it. Don’t.
Could you elaborate a bit?
I was under the impression that this was a good mod for 6 speed cars, picking as much as 50 hp on the dyno
it sucked , did it .... don't.
Im trying to follow
However its hard when you are just being told “dont do it”. Everyones experience differ depending on the car and the build. If i may ask, how far did you get into the build? At what point did you decide it wasn’t worth it?
The 6 speed cam is better, but not the best option. Get a custom grind if you are going to go through the work. The cam was our only option 8 years ago so a lot of people did it. The cam was a dyno monster that never translated into results on the track. This was the common experience.
Yes but “translating to the track” can mean many things, if it made the power on the dyno then its just transferring the power all that well, be it the high stall converter or whatever. If thats the case, wouldnt ANY cam run you through the same hoops? Isnt the whole purpose of a cam to open up the lift/exhaust and shift the power band?
Im sorry im no expert and have never swapped a cam into a car before. So i am mainly here to pick your brain. See, I’ve already went ahead and purchased a 6 speed cam for my 16’ M6 R/T. Got it fairly cheap brand new as a matter of fact and seemed like a good option
Best of luck.
Ok?
“Just get a custom grind” is not something i am able to pull off. Close to $1K to not be smog legal, (not everyone is building a racecar) with a custom cam. This factory cam not only will keep me CA smog compliant, but ill still get decent power gain.
