J t
2011 sxt to 2015 rt
I dont know what happened to what i typed but here it is again.
 First let me start by saying i am an auto tech. I have the skills,experience,and tools to be able to make the swap.
 I purchased a 2011 dodge challenger that was wrecked. I intend to build the way i want it. I replaced the body panels with used panels except for the hood. It is a 2019 redeye hood from dodge. Used new aftermarket bumper cover from Duraflex i wouldnt recommend them at all. Hard to fit and get right. Headlights and tail lights are aftermarket with sequential turn signals. I wanted a 6 speed and a 440 is in the cars future running factory fuel injection.  So i hunted down an. 2015 r/t from an auction. Intake and throttle body was busted. Car had 25k miles. I purchased a Holley intake and a 95mm throttle body. Pics show what it takes to fit the intake to the motor. I stripped the sxt and the r/t. These cars are built for a standard transmissions. If you look at the pics you can see 3 pedals and an automatic shifter. I switched everything including harness,diff and trans. Hardest part was modifing the sub frame to accept the new rack and pinion steering assembly. There was one hole i had to drill out on driver rear wheel well. I purchased the r/t with no key and reprogrammed a used key to start it. Some of the wiring was damaged on abs and tb so replacements were soldered in and shrink wrap was used for wiring. Hardest was finding a new tb plug. The r/t was struck by lightning while it was on my truck. Did serious damage to the fuse box unfortunately. Made more to be fixed. I made a hybrid of the ac system. Part '11 and part '15. Replaced the dash with a new one and installed it into the '11. Same with door panels. I switched everything salvageable off the '15.
 Holley didnt do theyre homework on the intake. It requires modifications to make it work. Im sure they get a lot of returns because of this. I mated a 95mm tb to it. I also installed long tube headers. I mated them to Borla s type exhaust.  The cold air intake was purchased from mopar and modified to be a ram air set up full functioning with the hood.  The r/t interior was cloth and i wanted leather. Found a guy selling the original seat covers out of a hellcat and bought them. I stripped the seats to the foam and installed the leather covers. So i currently have a 2011 sxt with a 2015 r/t car. Any questions,just ask.
20191216_111832(1)(1)(1).mp4
Thanks.
 So holidays are over and my pocket has allowed me to get front upper control arms and lowering springs. Put them in other day and car looks soooo much better now. Heres the pics
I like a t-handle shifter over a ball. Donor car had an aftermarket shift extension and ball. Never seen the ball was gone along with the key. So i purchased a t handle and modified the extension. Drilled the handle out and rethreaded it to 1/2 inch by 20. Ground the aluminum extension down and rethreaded it to the same. Heres a pic of how it looks.
 Also bought a 90° elbow thats 4inches on one side and 3.5 on the other end to allow for the cold air intake pipe.
