Sybil
Code P0300 misfire code on car with 21k miles?
Reset. P0308 #8 cylinder now. Swapped coil pack with # 6. Still has a P0308.  Can smell the rotten odor occasionally out of the exhaust. Oh brother here we go....
9 hours ago, Renfrick1 said:
Can you say fourtwentysix
Yeah I can say it.  Shouldn't need it it yet. Car breaks sitting in garage....
Replaced the crank and cam sensor because the were cheap. Didn't fix the problem but went from a P0300 to a P0308.  Swapped the  #8 coil pack AND PLUGS with # 4. Threw a P0304. Replaced the coilpack with a new mopar one. Did not fix the problem. Pulled the plugs, fouled from the failed coilpack. When these NGK's foul that's it..they are junk.
So # 8 coilpack failed , fouled the plugs so had to replace coil pack and plugs. If you are going to try swapping the coilpack trick to another cylinder, swap the plugs as well or you may get to buy 4 new spark plugs. :rolleyes:
