Transmission Shift Upgrade Valves/valve Body
Transmission Shift Upgrade Valves/Valve body
This article includes directions for removal and installation of both Shift Improvement Soleniods or Performance Valve Body. It also can be used for transmission filter service and oil change.
The NAG1 (new automatic gearbox 1) 5 speed automatic is the same transmission used by Mercedes (5G-Tronic/722.6) for years in the AMG performance series. Dodge/Chrysler made a few changes that down grade the performance. These changes included shift soleniods and clutch pack media. When in Mercedes trim it has the capacity of 798ft/lbs torque. In Chrysler trim it is rated at 427ft/lbs. When performing mods on your challenger and reach the 500+ rwhp mark. The line pressure is not great enough to hold the clutches properly engaged during shift changes. A simple modification to hold the transmission to around the 600 rwhp mark is to change either the entire valvebody to a performance unit or to simply change the shift soleniods to Mercedes units.
Valve Body Performance Upgrade can be purchased from Paramount Performance Products. Sold also by many Vendors.
Shift Soleniods Part# 240 270 00 89 can be purchased from Vendors or online at
MERCEDES-BENZ VALVE (240-270-00-89)
Tools Needed:
4 Jacks stands
Floor Jack
Small Jack and wood block (hold up rear of transmission)
7mm 1/4 socket
1/4 extension
1/4 ratchet
1. Raise car and place on jack stands.
2. Place small jack and wood block under rear of transmission behind the crossmember.
3. Remove the transmission crossmember to gain access to the transmission pan.
4. Disconnect the wire plug from the drivers side of the transmission.
a. Rotate the bayonet lock of the adapter plug counter-clockwise.
b. Using a 7mm socket, loosen the adapter plug bolt inside the hole. Remove the adapter plug from the transmission housing. There are 2 black O-rings on this adapter. Make sure they are still on when removed. If they are not on the adapter when removed you will have to retrieve them from the valve body when it is removed and place back on the adapter.
5. Place a large (CLEAN) oil pan under Transmission. Remove the pan from the transmission. Start from one end and work slowly around to drain oil into the catch pan. You will need to reuse the oil collected (not recommended) or measure to use the same amount of new oil.
6. Remove the filter by gently pulling down. More fluid will drain. Lay it in oil to reuse.
7. Unscrew 10 Torx socket bolts and remove valve body. Do not let it drop!
If swapping Shift Soleniods skip steps 8-16 (These deal with Peformance Valve Body exchange)
8. Remove the 3 small bolts & retainers that hold the solenoids down. Note one bolt is shorter.
9. Remove solenoids. Make sure to note locations of each.
10. The solenoid at the bottom left (converter solenoid) sometimes needs a bit of wiggling to remove.
Unsnapping the electrical connector plate (dipstick side)
11. On the electrical connector side, push the plastic tab toward the long plastic dip stick guide. The plastic pin will pop right out of the steel plate.
Unsnapping the electrical connector plate (slide piston side):
12. Rotate the temperature sensor SLIGHTLY counterclockwise to release the tab from the steel plate.
If your electrical connector looks like this on the underside of the electrical connector plate, your NAG1 is in BAD shape.
13. Reverse procedure to install the electrical plate.
14. It will simply clip into position.
15. Re-install the solenoids. Reference above photo for locations, actually they can not be installed in the incorrect position, they won't fit.
16. To install Use the same torque (71 in. lbs.) as all the other torx bolts.
Steps 17-19 only deal with Shift Soleniod replacement (Performance Valve Body install skip)
17. Lay Valve body on card board or towel.
18. Remove brown top soleniods only. (pictured above)
19. Replace with blue top soleniods. Torque torx bolt to (71 in/lbs)
Reinstalling Valve Body and Pan
1. Position the valve body in the transmission.
2. Insert selector valve (1) in driver of detent plate (2). This most be completed for transmission to function properly. Double check your work.
3. Reinstall the 10 bolts and torque to 71 IN/LBS NOT FT/LBS!!
4. Reinstall Filter. I would replace if you have over 30k miles or you have higher HP and have noticed transmission slip.
5. Reinstall the Transmission Pan and torque bolts to 71 IN/LBS NOT FT/LBS!!
6. Install the adapter plug back into the transmission housing and tighten the tiny bolt with a 7mm socket. Only snug it, do not torque!
7. Reinstall the plug connector (make sure the 2 O rings are in position)
8. Turn bayonet lock of adapter plug clockwise to connect plug connector
9. Reinstall Transmission crossmember.
10. Remove jack from under transmission and lower car to the ground.
11. Refill Transmission fluid (again not recommended) or use a measuring quart to get exact quantity and fill Trans with appropriate amount of ATF+4 fluid.
If you are uncomfortable with not knowing the exact level in your transmission. To check fluid level you have 3 options.
1. Have a dealer check it.
2. Purchase a NAG1 test dipstick Part# 9336A
https://millerspecialtools.spx.com/Detail.aspx?id=847
3. Use a long zip tie to bottom out inside the transmission.
on either 2 or 3 after 30 minutes of driving the fluid will be approximately 65mm up on the tool
Mike, glad to see you posted this here. I used this write-up when I did mine and it helped a lot since I have never been inside one of these NAG1's.
So I'm considering a supercharger upgrade for a 2012 SRT but I'm concerned about the transmission being able to handle the additional power.
What modification to the NAG1 would I have to do to be in the safe margin?
I'm assuming the NAG1 is the auto trans for both the RT and SRT?
I'm at 40K+ I probably should do a filter change. Might as well swap the solenoid while I'm in there.
Rayzazoo: I started with a good trans cooler before I got the Maggie. After the Maggie I did the Blue Tops with the Paramount Stage II Valve Body using GSO's instructions. Easy mod to do. Taking your time it should take you two hours to do the re/re. After that I did the MTCM upgrade from Arrington. Trans shifts beautifully! You will like! Yuuupppp.... your butt dyno will FEEL the shifts! :D
Just a' wonderin', how many RWHP does the blue tops make the NAG1 good for without upgrading the friction material? Stevo suh, ah suppose the cooler is to keep the higher temps down that a higher stall converter may cause?
Kenny.... that B&M Trans Cooler was one of the first mods I did. I once "cooked" an AOD trans in my 2year year old 1986 Mustang GT on a very hot day.... racing towards a city that was two hours away and I did it in just over an hour. I didn't want to make that mistake again. I have just moved the cooler from behind the bumper and up higher into the corner of the drivers side grill in order to get more air flow for even lower trans temps. My Aeroforce shows "AFR" on the top and "Trans Temp" on the bottom. I usually see temps around 185 degrees. I have never seen temps over 200 degrees. I believe anything over 220 degrees is harmful for the NAG1. I did the Valve Body/Blue Tops to increase line pressure and make the shifts quicker which lengthens the life of the NAG. From what I have read... the NAG is good for about 550 RWLHP with the mods I have. I am planning on doing a SHR Viking by CF5.
Whoops....looks like GSO beat me to it....
God no! Unless you want to strip out the trans case. It's aluminum
Well that was my thought but when talking to a friend he blurted out, "Just put locktite on it and be done.
I wasn't very keen with that idea but I thought I'd throw that out there ion case others were thinking the same thing.
Tools Needed:
4 Jacks stands
Floor Jack
7mm 1/4 socket
1/4 extension
1/4 ratchet
Is it just me or have the pics disappeared from this post???
edit: That's weird. When I look at the original post there are no pics yet when I quote it there they are!!! WTF?!?!?!?
Edited by CaptRon
It's you,
But bringing up this thread for John SRT5939  is like reading his mind before he asks the question! :)
Linda :)
But now John won't be needing this info anymore.
He is finally having a TH-400 installed, just like I did!
