Scorpionflame101
Locking Header Bolts
you can use oem bolts, wont be a problem....
or use serated flanged bolts ....
X2 just get OEM Bolts Part # 6503131, used them with headers on 3 different engines and multiple head swaps, they never come loose and work fine
Washers are not needed. Been using factory bolts for years and have never seen one loosen. Just make sure they have the yellow loctite on them ,if you get them new they come with the loctite already applied.
