Srt Engineer Chat Session On Lx Today 5-7 Est
Posted 21 September 2011 - 09:40 AM
9.59 @ 145MPH
VMP 10/10/2011
HHP/BES 6.1 Kenne Bell 2.8LC
200 NOS
Builder Bill Trans
Tuned by Brent at Dyno Tuned Performance
Home of the Fastest LX in the World
Posted 21 September 2011 - 10:13 AM
Posted 21 September 2011 - 10:43 AM
Posted 21 September 2011 - 11:18 AM
I posted up about the timing pull on shift for the 6 speeds along with a screen shot of my data log. We'll see if they touch that one.
Posted 21 September 2011 - 03:23 PM
LX Padiwan
Quote:
Originally Posted by spenvose
Why cant the Challengers come with a convienance spare tire in the car. The mini compressor is useless.
Why cant the after market make tuners for the 392 Challengers.
Thanks
1) The minispare does not clear the front brake caliper. Looking at the frequency of needing a spare tire these days and the fact that everyone has a cellphone to call for a tow, it is not worth carrying the extra weight. Feel free to install the minispare and jack out of the regular Challenger. If you get a flat on the front, put the minispare on the rear, and put your good rear tire on the front.
2) They haven't broken the code, yet. It is a rolling code, like your garage door opener!
Posted 21 September 2011 - 03:29 PM
Posted 21 September 2011 - 03:42 PM
Posted 21 September 2011 - 03:58 PM
SRTEngineers
LX Padiwan
Since you've changed a lot on your engine, the airflow fed buck bobble calibrations are off causing this. The 6spd cars are very sensitive to this, which is why they are calibrated as they are in production. When you start changing parts that affect airflow, these things can happen...
Quote:
Originally Posted by Speedy!
2009 6 Speed Challenger Arrington forged 6.0L stroker Magnuson blower
I've noticed in my data logs from the drag strip that my car is losing an exorbitant amount of timing after I shift gears and it takes 1.5 - 2 seconds to start to recover. I'm talking single digit timing after a shift here and it's killing the 6 speed's ability to perform on the track as compared to the auto.
This isn't isolated to just my car, every 6 speed data log I've seen is doing the same thing.
Can you give some insight on why this is occurring on only the 6 speed cars and not the autos? Is it torque mgmt or something else and can you give any insight on how to defeat it? The car is in dyno mode, which I thought defeated all torque mgmt?
Auto cars with similar mods are running .5 - .7 better ETs and I believe this has a lot to do with it.
Here's a screen capture of a data log showing the issue. Note the car dropped to 4.5 degrees of timing after a shift and I'm at WOT. Green line is actual spark cyl 1 pid, purple is throttle blade position, and brown is MAP. The highlighted area of the log is the 2-3 shift point showing 4.5 degrees of actual timing. Car has ZERO KR.
Another interesting one. Looks like upgrading to SRT brakes on RTs isn't the best idea.
SRTEngineers
LX Padiwan
Quote:
Originally Posted by Hammer Harry
I own a 2010 300C and was wondering is it possible to install the brembo brakes from the SRT8 300? Will the stock 300C master cylinder and proportioning valve work with the Brembos? What other changes will be required?
Thanks
Posted 21 September 2011 - 04:16 PM
Posted 21 September 2011 - 05:46 PM
I wonder if Dodge will be surprised when they discover they can't break the code to increased sales.
09 R/T 6 speed / 8psi Maggie
Can you spot the AN?
Posted 21 September 2011 - 06:40 PM
Posted 21 September 2011 - 08:33 PM
J - don't believe too much B.S. on the brakes. I've got a big brake kit and the ABS works perfectly fine. Obviously I shut it down or largely negate it when I'm circle tracking or straight line racing, but why would SRT brakes be much different than an aftermarket kit in that regard??? A bunch of corporate hoaky. Might as well have attorneys on the chat sessions. Hell, maybe they do...
Posted 21 September 2011 - 09:18 PM
F1d ProCharged 426
Posted 21 September 2011 - 11:45 PM
Renfrick1, on 21 September 2011 - 06:40 PM, said:
It's pretty obvious that they don't give a shit about anyone wanting to put on a tune.
And are either too self absorbed or stupid to realize it will hurt sales on the 2011+ cars.
They're also either being complete dicks (hence the
) or they are planning to sell tunes straight from Mopar Performance.Because it was pretty much the underlining theme to the questioning... and they basically ignored all comments related to it.
... 53% 2010 Challenger 6sp Mopar10 & 2009 300c Black (The wife's)
1974 Challenger 360 Auto & 1998 Ram (for Towing)
1970 Road Runner 440+6 4sp & 1966 Charger 383 4sp
Posted 22 September 2011 - 05:27 AM
lakersfan7272, on 21 September 2011 - 09:18 PM, said:
Maybe SohFast, AJ or Blown7 could shed some light?
Even if it is a 'real' table, cars that are not modified are pulling timing as well, not just modified engines.
Posted 22 September 2011 - 05:36 AM
