Predator Strange Problem
Posted 12 February 2011 - 01:04 PM
After I got to work, I put the stock tune back in the car and took it for a drive during lunch. No KR at all. I drove it good and hard and even WOT, no KR. I'm totally stumped.
My current plan is to run this tank of 91 out and then fill up somewhere else, and then try again. I'm also going to hook the laptop up and do some datalogs that I can post. But I do not understand why I'm getting knock even just barely touching the throttle down below 2000 RPM with the canned tune.
The car is practically new, only 3000 miles on it. I've had no issues with it at all before trying the Predator, it runs like a dream.
I also have a thread going at the diablosport forum:
http://diablosport.c...ewtopic&t=27322
Any thoughts for this n00b?
Posted 12 February 2011 - 01:08 PM
Posted 12 February 2011 - 01:14 PM
Posted 12 February 2011 - 01:20 PM
Any audible pinging is definitely bad for your engine - I would revert to the stock tune ASAP and get it figured out.
Posted 12 February 2011 - 05:05 PM
You can keep Christ in Christmas, but get him the fuck out of Saturnalia!
Posted 12 February 2011 - 05:27 PM
Gnostic, on 12 February 2011 - 05:05 PM, said:
Hey G, Whats common? Shity gas or It knocking on the 91 tune?
Thats My biggest fear is gatting a tank of shity gas, Does'nt go good with high boost.lol
Posted 12 February 2011 - 05:29 PM
Posted 12 February 2011 - 06:12 PM
I need to see a few pids like:
desired FA cyl 1
st kr
lt kr
knk sensor 1 (mvs)
knk sensor 2 (mvs)
actual spark cyl 1
Engine speed (rpm)
Throttle Position %
I don't need a half hour log either, just a couple minutes of each. On the 91 canned tune log, make sure the log shows the problem.
I always use Shell 93 in mine as well as my SC 4Runner. They're a top tier gasoline and have to maintain a cert to keep the designation. Never had any issues with their gas and I've used it exclusively for going on 4 years in my FI cars. It's the best I can get in my area. Wish we had Sunoco 94 though.
Posted 12 February 2011 - 06:15 PM
Posted 12 February 2011 - 06:33 PM
and mike... you just beat me out on the torco
Posted 12 February 2011 - 07:27 PM
Posted 12 February 2011 - 09:24 PM
Well, both, I guess. Maybe too strong to call it shitty gas, just a lower octane than advertised. So it causes knock, which is how I found out that I needed to go with the "93" octane. It's probably actually only 91, so the 91 tune works with it. But the "91" octane around here is probably 89, so it knocks. This is Shell gasoline, btw, and I've run tests to find out that Shell's gas is no better in this situation than my local Sheetz's gas (Sheetz is a convenience store chain popular in this part of the country).
With high boost, though, you're in a custom tune anyway, and have no use for the canned tune.
Posted 12 February 2011 - 09:27 PM
How did you test the fuel? I wouldn't mind sending some samples off to see what I see with my local stuff.
Posted 12 February 2011 - 09:31 PM
desired FA cyl 1
st kr
lt kr
knk sensor 1 (mvs)
knk sensor 2 (mvs)
actual spark cyl 1
Engine speed (rpm)
Throttle Position %
Thanks Speedy. I'll generate some logs on my next fill up. I really don't want to run the 91 octane tune on this tank full again, the knock was bad. Hopefully, with the next fill up things will be fine and I won't even need to post up some logs.
Unfortunately, I'm in CA, so the best I can get is 91. I was thinking Chevron this time around.
gsochallenger, on 12 February 2011 - 06:15 PM, said:
LMFAO!!!
gsochallenger, on 12 February 2011 - 07:27 PM, said:
I'm in CA bro.
Hey guys, thanks for all the responses!
Posted 12 February 2011 - 09:32 PM
Posted 12 February 2011 - 09:38 PM
WORK IN PROGRESS, on 12 February 2011 - 09:32 PM, said:
<br><br>Your tuner should build some safeties in to the tune. For example, when it's hotter out my car runs less timing than when it's colder. Same thing for bad gas. So you get a tank of bad fuel, it knocks and the sensors pull timing. The car won't run as well but atleast the motor is safe.
Posted 12 February 2011 - 09:42 PM
Speedy, on 12 February 2011 - 09:27 PM, said:
I just mean that I ran some logs with the Shell 91, then with their 93, then with the Sheetz 91 and 93 (all of this with the canned 91 tune). As far as knock, the two brands were about the same. With 91 octane, they both showed a good deal of short-term knock, especially at shift points. The Shell 91, in fact, even showed some long-term knock. With the 93 octane from both places, there was no more long-term, and just a couple instances of mild short-term (not so much that I can't live with it).
Posted 13 February 2011 - 08:37 AM
F1d ProCharged 426
