Ram Air Hood Posts Are Taped In?
speedlogix hood problems
31 replies to this topic
Poll: Beauty or Function? (10 member(s) have cast votes)
Do you think the aluminum threaded standoffs on Speedlogix's hood should be fastened or taped in place?
  1. fastened (10 votes [100.00%] - View)
    Percentage of vote: 100.00%
  2. taped (0 votes [0.00%])
    Percentage of vote: 0.00%
  3. both (0 votes [0.00%])
Vote Guests cannot vote
#21
Knownman
Knownman
  • 1,292 posts
It's definitely 6mm threads.
I found some socket head cap screws that thread all the way in. I measured the pitch with a gauge. I originally thought the screws were 1/4-28. I couldn't get one to thread past the third thead so I broke out my screw thread chase set. 6mm was the right one.
I just want all the hardware to be the same. Those screws you have there are button head cap screws. The ones in question are round head and have a different, lower profile and are phillips driven.
Hence why I'm on the hunt for two more screws and washers.
#22
Highwayflyer
Highwayflyer
  • 71 posts
how are you going to put the screw in ?   my post came loose and turned around making round scratches inside the scoop on the top part of my hood.  are you going to drill through the top of the scoop ?
Knownman
Knownman
  • 1,292 posts
The top of the scoop has a threaded boss molded in it. This is where the threaded rod that is installed in the support should be screwed in.
It's the bottom that was taped. The part on the hood. A thru hole will do as it is a single layer of fiberglass there. Problem will be trying to get to it as the access hole for the front hood latch has to be used. I will probably drop another thru hole in that lower part of the fiberglass just large enough for the Phillips driver. Then I'll use a angled hemostat to hold the screw and thread that thru the opening. And then drive the screw to with the phillips. Sounds harder than it will be as long as I don't drop the screw in the process.
I manage a motion picture cameras rental house for a living so I'm real used to unusual mechanical workings. And very precise measurements. Most of our equipment requires a maximum tolerance of 1/100 of a millimeter. Roughly 4 ten-thousandths of an inch for you yanks.
#24
Highwayflyer
Highwayflyer
  • 71 posts
duct tape is the answer.   it will help cover the scratch.
Speedlogix Mikey
Speedlogix Mikey
  • 621 posts
To get the bolts that hold the scoop to the hood it would be: $24 shipped. Manufacturer will only sell them as a set, no way to separate them.
Let me know
Thanks
Mikey
#26
Knownman
Knownman
  • 1,292 posts
Okay,
Twenty four bucks for two screws.
Will you at least buy me dinner first?
#27
  • 7,704 posts
Okay,
lol what you don't want a kiss too?
            Drag Pak pictures
#28
Shaggy SRT
Shaggy SRT
  • 2,837 posts
Looking for something like this?
http://www.fastenal....qId=&rfqLineId=
challengeratco-22012-1.jpg   ]11SecondClub-5_zpsda2fd96b.gif[
[c0f14c68-ce5c-4246-9be7-2bbdb9f11d00_zps56142259-73d3-49dd-8429-d5a29edbba10_zps
#29
  • 748 posts
Wow.
I would have thought you'd have received the screws in the mail by now at no charge.
Performance Werks Racing (PWR) 426 Stroker / Apache Heads / Fr-240 Cam
Install by HalfFast Performance
Tune by JerseyBoy
#30
Highwayflyer
Highwayflyer
  • 71 posts
are you gonna put screws through the top of the scoop ?     I aint to hip on that, gotta be a better way then screws showing on top of my hood.
Knownman
Knownman
  • 1,292 posts
Not on the top of the scoop.
There are threaded bosses on the bottom of the scoop. That's where the support rods screw to.
It's underneath on the hood where the support rods are held with tape. There should be a thru hole here and the screws thread up into the rods. Everything would be hidden if done properly.
But like they said it isn't designed like that!
#32
Highwayflyer
Highwayflyer
  • 71 posts
Oh I see now said the blind man.    ready for a fix myself,  thanks
