My cam sensor is leaking oil. The dealership is ordering me a new one to replace it. Is there anything I should be concerned about in regards to replacing this sensor? Anything the dealership can screw up when doing this?
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. This message will be removed once you have signed in.Login to Account Create an Account
Cam Sensor Replacement
Started by sharkcohen, Apr 18 2011 01:31 PM
5 replies to this topic
Posted 18 April 2011 - 01:31 PM
Posted 26 April 2011 - 05:35 PM
just noticed this thread, you'll be fine. its a simple fix
make sure your stock tune is in the car
Posted 27 April 2011 - 10:54 AM
DUDE, I dodged a bullet on that one, I DID forget to put the stock tune back in. I got lucky, they didn't flash the PCM.make sure your stock tune is in the car
Posted 27 April 2011 - 12:29 PM
Lucky indeed! My dealer knows not to jack with my car. I guess I should put on that Magnuson "lock" but it's a bit of a joke and I've got my Aeroforce gauges hooked up. Fortunately not a problem so far and A.J. is good to me and e-mails me the tunes so I can reload if need be. The biggest risk is a new CAL ID and then the tunes would have to be "adjusted".
Posted 27 April 2011 - 12:51 PM
